[Proj] UTM Zone projection parameters to pass to pj_transform()
Ed McNierney ed at topozone.com
Mon Nov 28 13:13:46 PST 2005
David -
It is also possible to have a rectangle in UTM space contain points that
are NOT inside the quadrilateral formed by connecting the four
reprojected corner points into lat/lon space.  Conversely, there can be
points inside that lat/lon quadrilateral that were NOT inside the UTM
rectangle.  You might need to keep that in mind depending on how fussy
your application is.
	- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA  01863
ed at topozone.com
(978) 251-4242
-----Original Message-----
[mailto:proj-bounces at lists.maptools.org] On Behalf Of Jacques, David -
Fort Worth, TX
Sent: Monday, November 28, 2005 4:01 PM
To: proj at lists.maptools.org
Subject: [Proj] UTM Zone projection parameters to pass to pj_transform()
Actually now that I think about it it makes sense.
If it is square in UTM... It will be rotated somewhat.
So nix that last comment.
David
Proj mailing list
Proj at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/proj
