[Proj] Ukraine towgs84
Oscar van Vlijmen
ovv at hetnet.nl
Wed Nov 30 03:43:42 PST 2005
> I've been looking for a possibly accurate datum shift for Ukraine from
> Krassovsky to WGS84.
> Does anybody know of a Ukraine dedicated, possibly 7-parameter, towgs84
> shift?
I found an article about GPS on:
http://www.geomatica.kiev.ua/training/DataCapture/GPS/chapter100.html
Scroll down to table 1.1. There you'll find 7-parameter data for the
transformation between PZ-90, SK-42 and WGS84, valid for Ukraine. Since
section 1.3 describes the position vector transformation method, I assume
the parameters are for that type of transformation too.
The article is in Russian.
Probably something useful can be found at the site of the Ukrainian
"Scientific Research Institute for Geodesy and Cartography" (my translation)
http://www.gki.com.ua/
So far I've only found an article about the _method_ of finding parameters
for the transformation between the "state geodetic systems" and the "global
system" WGS-84:
http://www.gki.com.ua/DyWP/bindata/_0000940_file.pdf
but no actual parameters for SK-42. Or did I misread something? My Ukrainian
is a bit rusty...
More information about the Proj
