[Proj] Meaning of 7-parameter transformation rotations
Frank Warmerdam
warmerdam at pobox.com
Wed Nov 30 11:16:46 PST 2005
On 11/30/05, Clifford J Mugnier <cjmce at lsu.edu> wrote:
> Gentlemen:
> Note that the SENSE of the rotations have two common usages. The American
> Standard versus the European Standard differ! To transform in the same
> direction, the signs are OPPOSITE from one "standard" to another.
> Generally speaking, a 7-parameter transformation, whether it is a
> Bursa-Wolfe or a Molodensky, MUST have a "test point" provided so that the
> user knows which sense the rotations need for the desired transformation
> direction.
> The Americans, Australians, and Luxemborgs use one SENSE, the Europeans use
> the other. In regard to the rest of the world, it depends on which
> brand-name of GPS Geodetic Processing software was used to derive the
> parameters from some collection of data points. See my monthly column for
> such important minutiae for country to country considerations.
> Be careful of 'dem signs! :-)
Cliff,
Your point is quite correct. I believe that PROJ
is using the European definition so that we can directly
apply the numbers from EPSG.
Test points are always a good idea. I wish the EPSG
database came with a test point for each coordinate system.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
More information about the Proj
