[Proj] Snyder ISEA
Lili Zhang zhangli at supermap.com
Wed Oct 19 04:57:26 PDT 2005
Strebe,
    Many thanks for your reply.
	The acronym ISEA stands for icosahedral Snyder equal area.
    I got to know ISEA at the website: http://www.sou.edu/cs/sahr/dgg/isea/isea.html
    I am doing some work on hierarchical spatial partitioning method on the ellipsoid suface with equal erea.
    So ,the paper An equal-area map projection for polyhedral globes maybe is very important for me.
    Is there any resource code that implemented Snyder's equal-area map projection ?
======= 2005-10-18 23:46:25£º=======
>Snyder described at least three methods for creating customizable equal-area
>projections, as well as an equal-area projection for arbitrary polyhedral
>faces. I'm not aware of any of them called "ISEA".
>See:
>"Optimizing equal-area map projections using least squares", American
>Congress on Surveying and Mapping, Reno, ASPRS-ACSM 1987 Fall Convention, ACSM
>Technical Papers, p. 5-13.
>"An equal-area map projection for polyhedral globes," Cartographica, Vol. 29,
>No. 1, Spring 1992, pp. 10-21.
>"New equal-area map projections for noncircular regions," The American
>Cartographer, Vol. 15, No. 4, October 1988, pp. 341-355.
>"Minimum-error equal-area map projections," (with John A. Dyer), The American
>Cartographer, Vol. 16, No. 1, 1989, pp. 39-43.
>Regards,
>daan Strebe
>In a message dated 10/18/05 09:53:13, zhangli at supermap.com writes:
>> Hi,
>>    Does someone know?Snyder Equal Area (ISEA) projection?   Or where can I
>> find some information about this projection ?
>>    Any suggestions is appreciated.
>>    Thanks.
>_______________________________________________
>Proj mailing list
>Proj at lists.maptools.org
>http://lists.maptools.org/mailman/listinfo/proj
¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡ÖÂ
Àñ£¡
¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡Lili Zhang
¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡zhangli at supermap.com
¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡2005-10-19
