[Proj] reprojection of sites within SHP file to standard output
Bruce Raup brauplists at gmail.com
Tue Sep 13 12:50:03 PDT 2005
Shapelib has a contributed utility "shpproj" which can do this.  --Bruce
2005/9/13, Dave Sampson <gis at watersheds.ca>:
> pw,
> I seem to remember reprojecting SHP files before. PROJ was even creating
> a new PRJ file for me. I thought that if Proj can reproject a whole
> shape file that it might be able to do components thereof.  The script
> you speak of, is it an avenue script?  ANy open source solutions as I am
> avoid running arcview. proof of concept.
> cheers
> > Hello,
> > Can this actually be done with proj...?(Didn't think so)
> > SHP files are ~proprietary to arcview GIS. There is a
> > format spec available on the web.
> > I have an arcview script for dumping coordinates
> > from SHP files to ascii text, if that helps. I believe it also
> > dumps one attribute as well, allowing you to link
> > the geographic data with the data in the accompanying
> > DBF file. In any case you could modify the script to
> > dump what ever you want.
> |Dave Sampson: Geographic Information System (GIS) Technician   |
> |Centre for Sustainable Watersheds                              |
> |Cooperative Approaches to Protect Canada's Water Resources     |
> |14 Water St, P.O Box 280. Portland Ontario, Canada. K0G 1V0    |
> |Lat: 44.700    Long: -76.19                                    |
> |www.watersheds.ca              gis at watersheds.ca               |
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
Bruce Raup
http://cires.colorado.edu/~braup/
