[Proj] UTM ED50 to ETRS89 datum shift problem
karel cech
cech.karel at gmail.com
Mon Dec 4 09:32:34 PST 2006
Jose,
thanks a lot, what a mistake...
Now I have only 5m error in northing and 2m in easting which is OK for
my purpose I think.
720827.53 4376363.70
On 12/4/06, José Alberto Gonçalves <jagoncal at fc.up.pt> wrote:
> It seems that your input is not correct. You must input one point per
> line, with x and y separated by space or tab.
> I didn't check the command line.
> Jose' Gonçalves
> karel cech wrote:
> > Hi list,
> > I have a problem with changing datum with cs2cs using 7 parameter
> > shift from ED50/UTM30 to ETRS89. The result differs a lot from
> > transformation results made by Carthographic Institute of Valencia
> > (they work with ESRI and ERMapper)
> > My test point has following coordinates (ED50/UTM30, EPSG:23030)
> > 720931.9
> > 4376574.85
> > What I would like to obtain is aproximatly this (ETRS89, EPSG:25830):
> > 720821.51
> > 4376365.31
> > However, cs2cs gives me
> > 720748.93
> > 4376357.47
> > The 7 parameters are defined by spanish institutions.
> > The debug output from cs2cs (proj 4.4.9.):
> > cs2cs -v +proj=utm +zone=30 +ellps=intl
> > +towgs84=-131.0320,-100.2510,-163.3540,1.2438,0.0195,1.1436,9.3900
> > +units=m +to +proj=utm +ellps=GRS80 +zone=30 +units=m -r <<EOF
> >> 720931.9
> >> 4376574.85
> >> EOF
> > pj_open_lib(proj_def.dat): call
> > fopen(/usr/local/proj4/share/proj/proj_def.dat) - succeeded
> > # ---- From Coordinate System ----
> > #Universal Transverse Mercator (UTM)
> > # Cyl, Sph
> > # zone= south
> > # +proj=utm +zone=30 +ellps=intl
> > # +towgs84=-131.0320,-100.2510,-163.3540,1.2438,0.0195,1.1436,9.3900
> > # +units=m
> > # ---- To Coordinate System ----
> > # Cyl, Sph
> > # zone= south
> > # +proj=utm +ellps=GRS80 +zone=30 +units=m
> > -67.69 720748.93 175.19
> > -102.91 4376357.47 82.19
> > I am sure have missed something or misunderstood proj. For, example,
> > according to manual, using 7parameters shift provides the option
> > +towgs84, but, I don't output to wgs84.. Do you use +towgs84 in
> > similar tasks?
> > Thank's in advance for any ideas,
> > Karel
> > Proj mailing list
> > Proj at lists.maptools.org
> > http://lists.maptools.org/mailman/listinfo/proj
> Proj mailing list
More information about the Proj
