[Proj] Insignificant difference between Swiss and Hungarian Oblique Mercator?
Mikael Rittri
Mikael.Rittri at carmenta.se
Tue Dec 5 04:53:22 PST 2006
Hello,
I think I have implemented the Hungary EOV projection, which is a
generalization
of the Swiss Oblique Mercator (+proj=somerc). In the Hungarian version,
you
can specify a normal parallel, distinct from the central one. The
_normal_
parallel gives the center of the first step of the double projection
(ellipsoid -> sphere), while the _central_ parallel gives the center
of the second step (sphere -> oblique cylinder).
I've modified the code of the PROJ.4 somerc, to cover the Hungarian
usage as well, but I am rather surprised: the effect of having
normal parallel != central parallel is about 0.01 millimeters.
Yet, to quote Molnar and Timar,
http://www.fomi.hu/honlap/magyar/szaklap/2002/03/mar3.pdf ,
"its normal parallel slightly but intentionally differs ..." [from the
central one].
But I cannot understand the intention, if the difference in projected
coordinates
is so small. (And I don't read Hungarian; only the abstract is in
English).
I've read on this list that PROJ.4 users do use +proj=somerc for
Hungary,
but I thought the approximation would be worse. Just to rule out the
possibility that I have made a silly mistake: could anyone confirm that
the approximation error is about 0.01 millimeters?
Best regards,
-- Mikael Rittri
Hungary EOV specification: http://lazarus.elte.hu/gb/geodez/geodind.htm
(chapter 2 and 9).
My test points used the projected coordinates roughly in the four
corners of
Hungary, which I unprojected with and without the distinct normal
parallel.
The differences were:
Easting Northing Difference
400000, 0 -> 0.01350 mm
400000, 400000 -> 0.01399 mm
900000, 0 -> 0.01350 mm
900000, 400000 -> 0.01399 mm
More information about the Proj
