[Proj] Aitoff projection
Norman Vine nhv at cape.com
Thu Dec 14 14:51:08 PST 2006
Antonio writes:
> Do you know if tha Aitoff projection is supported in the current Proj
> 4.4.9 release?
Yes
> and if so, what kinds of parameters I need to put in my mapfile.
I think this should work
"+proj=aitoff +lon_0=XXX"
Where lon_0 is central meridean of desired map
HTH
Norman
