[Proj] cs2cs how to use
davidvaz
davidvaz at ncc.up.pt
Wed Feb 15 11:06:07 PST 2006
It's me again!
Frank Warmerdam wrote:
> As Cliff mentions, the above does not include information on the datum
> shift to be applied between WGS84 and "datum 73". I believe the
> following
> commandline would use the above parameters and Cliff's suggested datum
> shift.
> cs2cs +proj=wgs84 +datum=WGS84 +to \
> +proj=tmerc +k=1 +lon_0=-8.131906111111112 +lat_0=39d40 \
> +x_0=180.598 +y_0=-86.66 \
> +ellps=intl +towgs84=223.116,-106.825,-36.87
I tried this commandline but all I've got was an error:
Using from definition: proj=wgs84 datum=WGS84
Rel. 4.4.9, 29 Oct 2004
<lt-cs2cs>:
projection initialization failure
cause: unknown projection id
program abnormally terminated
Do you know what might be the problem?
Thanks for the help.
David Vaz
More information about the Proj
