[Proj] Re: [UMN_MAPSERVER-USERS] Polar reprojection (again)
Frank Warmerdam
warmerdam at pobox.com
Thu Feb 16 20:10:38 PST 2006
Christopher Condit wrote:
> Hi Frank-
> I'm attaching a zip file with two simple mapfiles illustrating the
> problem. There's a README.txt in zipfile that describes everything.
> Thanks for your help!
Chris,
Gee, I hope that big attachment didn't actually go to the list!
I dug into the problem and it turned out to be unusual.
The raster resampler calls PROJ.4's pj_transform() function for one
whole row of points to transform at once. The idea is that pj_transform()
returns a success flag for each point. But some kinds of errors are
considered to be "non-transient", and it is assumed if they are encountered
for one point they will apply to all points.
It turns out that getting errno=33 (EDOM) or errno=34 (ERANGE) from
math library functions (like atan) were considered "non-transient" by
pj_transform(), even though they are likely to only apply to some points
in a group. Because your initial range +-10000000 was invalid to reproject,
and because the error was improperly considered non-transient the code
was assuming all the points would fail and giving up.
Using a smaller initial EXTENT (ie +-5000000) was enough to get a reason
result. But better than that, I was able to correct the PROJ.4
pj_transform() function.
The upshot is that if you can grab the latest PROJ.4 source from CVS and
build it, you can get correct behavior. Since I wouldn't be surprised
if that is messy for you, I have also put the modified pj_transform.c
on my web site at:
http://www.gdal.org/tmp/pj_transform.c
If you grab that and dump over the PROJ 4.4.9 src/pj_transform.c file,
build and install it, you should be ok.
Thanks for providing a concise demonstration of the problem so I was
able to track it down fairly easily.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
More information about the Proj
