[Proj] Problems Migrating to .net 2.0
Ed McNierney
ed at topozone.com
Tue Feb 21 09:57:25 PST 2006
Eric -
No, proj doesn't come with C# wrappers - but you wrote one! That's the
wrapper Scott is using; see
http://lists.maptools.org/pipermail/proj/2004-September/001338.html for
the source.
- Ed
-----Original Message-----
[mailto:proj-bounces at lists.maptools.org] On Behalf Of Eric Miller
Sent: Tuesday, February 21, 2006 12:23 PM
To: proj at lists.maptools.org
Subject: Re: [Proj] Problems Migrating to .net 2.0
Since proj doesn't come with C# wrappers, we can't guess how the C#
function call imports are defined.
Nevertheless, you don't do any error checking. Are you sure your
pj_init_plus calls are succeeding? Their definitions look suspect to
me...
IntPtr src0 = proj_api.Proj.pj_init_plus("+proj_api.Proj=latlong
+datum=NAD27"); """
>>> scott at topozone.com 2/21/2006 7:51:29 AM >>>
Hello,
I've recently moved my project from .net 1.1 to .net 2.0
I've tested this code on 1.1, but there are some added restrictions and
stuff that just won't compile in 2.0.
This is the C# wrapper that I'm using
"Attempted to read or write protected memory. This is often an
indication that other memory is corrupt."
public static int LLtoUTM(int datumIn, int datumOut, double
p_lat, double p_lon,ref double UTMNorthing,ref double UTMEasting,ref int
UTMZone)
int errno;
//This is the formula for calculating which Zone a
point is in at a particular lat/long
int ZoneNumber = Convert.ToInt32((p_lon + 180) / 6) +
1;
double[] x = new double[1];
double[] y = new double[1];
double[] z = new double[1];
y[0] = p_lat*proj_api.Proj.DEG_TO_RAD;
x[0] = p_lon*proj_api.Proj.DEG_TO_RAD;
z[0] = 0.0;
IntPtr src0=
proj_api.Proj.pj_init_plus("+proj_api.Proj=latlong +datum=NAD27");
IntPtr src1 =
proj_api.Proj.pj_init_plus("+proj_api.Proj=latlong +datum=NAD83");
IntPtr dst0 =
proj_api.Proj.pj_init_plus("+proj_api.Proj=utm +zone=" + ZoneNumber + "
+datum=NAD27");
IntPtr dst1 =
+datum=NAD83");
//This nice little bit of code below is designed to
execute pj_transfrom (the proj_api.Proj lib all around function)
//with the correct parameters so that a datumshift to
the correct datum is included.
if(datumIn==0)
if(datumOut==0)
errno = proj_api.Proj.pj_transform(src0,
dst0, 1, 1, x, y, z);//NAD27-NAD83
else
dst1, 1, 1, x, y, z);//NAD27-NAD27
else
if(datumOut==0)
errno = proj_api.Proj.pj_transform(src1,
dst0, 1, 1, x, y, z);//NAD83-NAD27
else
ERROR THROWN HERE -> errno = proj_api.Proj.pj_transform(src1, dst1,
1, 1, x, y, z); //NAD83-NAD83
proj_api.Proj.pj_free(dst1);
proj_api.Proj.pj_free(src1);
proj_api.Proj.pj_free(dst0);
proj_api.Proj.pj_free(src0);
UTMNorthing = y[0];
UTMEasting = x[0];
UTMZone = ZoneNumber;
return errno;
Any help would be appretiated.
Thanks!
-Scott
Proj mailing list
Proj at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/proj
More information about the Proj
