[Proj] Finnish KKJ in proj 4.4.9 - Linux vs. Windows
Tue Jan 3 14:02:48 PST 2006
Roger,
I got matching results on Linux and Windows:
cs2cs +proj=latlong +ellps=WGS84 +to +init=esri:2393
24d52.87822 60d12.21644
3382686.81      6678774.91 -24.59
I also verified this with the FWTools binaries for cs2cs.
Could you try cs2cs on each platform?  Then perhaps try
the cs2cs that is part of the FWTools build?
The cs2cs should be doing essentially the same thing as
your program.
Best regards,
