[Proj] proj and Dutch RD
Jan Hartmann j.l.h.hartmann at uva.nl
Wed Jan 11 09:56:15 PST 2006
Gerald I. Evenden wrote:
> Given the following script:
> vala=" +ellps=WGS84 +proj=stere \
> +lat_0=52.15616055555555 +lon_0=5.38763888888889 +k=0.9999079 \
> +x_0=155000 +y_0=463000"
> valb=" +ellps=WGS84 +proj=sterea \
> cat <<EOF >data
> 5.38763888888889 52.15616055555555 at the origin
> 5.88763888888889 52.65616055555555 1/2 degree from origin
> 6.38763888888889 53.15616055555555 1 degree from origin
> EOF
> echo "using Snyder Stereographic"
> ./lproj $vala data
> echo "using Double Stereographic"
> ./lproj $valb data
> where the test values are at the center of the projection and intervals of 1/2
> degree and 1 degree (in both latitude and longitude) from the origin.  The
> script generates the following output:
> 155000.00       463000.00 at the origin
> 188832.98       518750.23 1/2 degree from origin
> 221895.96       574738.50 1 degree from origin
> 188832.02       518749.72 1/2 degree from origin
> 221892.14       574736.46 1 degree from origin
> Note that there is no difference at the center or projection origin but the
> projections differ by several meters at a distance of 1 degree from the
> origin.
Yes, the PROJ-definition for the Dutch coordinate system (RD) should be
"sterea", not "stere". The problem is that the EPSG data-file in the
PROJ-distribution has "stere" for RD (epsg:28992), although he original
EPSG database has the correct definition: Oblique Stereographic.
Attached two images with projections from latlon to RD, giving the
differences between PROJ's "stere"/"sterea" projections and the official
Dutch converter ad http://www.rdnap.nl.
Jan
Type: image/gif
Desc: not available
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20060111/5ec46c40/attachment.gif>
Type: image/gif
Desc: not available
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20060111/5ec46c40/attachment-0001.gif>
