[Proj] Using pj_transform API to convert WGS84 to OSGB
John Smart
john.smart at caris.com
Fri Jan 20 04:42:29 PST 2006
> double x = 55.863157, y = -4.432298, z = 0;
I could be missing something here but haven't you got your x and y mixed up?
Your command line test had x=-4 and y=55 (4w and 55n).
If I do your command line test with the mixed up values I get:
55.863157 -4.432298
8256101.80 -6437819.18 599.248
(I was supposing maybe I'd get the same message as you).
maybe there's some sanity checking going on in the code, since a Transverse
Mercator projection generally isn't useful so far away from its origin.
Just a guess. Good luck.
More information about the Proj
