[Proj] Updated epsg file
Wed Jan 25 10:23:47 PST 2006
On 1/25/06, Brian Peschel <brianp at occinc.com> wrote:
> Any know where I can get an updated epsg file
> (/usr/local/share/proj/epsg)?  I am using 4.4.9 with the US datum
> extension (proj-4.4.9.tar.gz
> <ftp://ftp.remotesensing.org/proj/proj-4.4.9.tar.gz> and
> proj-datumgrid-1.3.zip
> <ftp://ftp.remotesensing.org/proj/proj-datumgrid-1.3.zip>).  The epsg
> file in my build directory is dated May 12, 2004.  Basically, I need to
> get the values for epsg code of 102185 which I have seen support for in
> other applications (like FME).
Brian,
Codes like 102185 are not real EPSG codes, they are
ESRI extensions.  If you look at the nad/esri file you
will find a translation of the ESRI coordinate system codes,
but they seem to be somewhat out of date, since there is no
102185 in there.
Best regards,
