[Proj] Roussilhe Projection
Steffen Macke
sdteffen at gmail.com
Tue Jan 31 21:56:13 PST 2006
Hello All,
I tried to move the Roussilhe projection from
http://members.verizon.net/~vze2hc4d/proj4/lbp4-3_060124R.tar.gz
to proj.4.4.9. I attached a patch with the changes I did to make things compile.
However, while Gerald Evenden's package works fine, my patched proj does not
work.
E.g.
echo 36.176039 31.203685 0 | ./proj +to +proj=rouss +ellps=clrk80
+rf=293.46 +a=6378249.2 +lon_0="39d09'E" +lat_0="34d12'N"
+k_0=0.9995341
gives
-1.#J -1.#J 0
Did I miss anything?
Regards,
Steffen
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20060201/e9a91884/attachment.obj>
More information about the Proj
