[Proj] Michigan Georef projection support?
Clever, Max
Maxc at spicergroup.com
Thu Jul 20 07:23:22 PDT 2006
Hello Proj Developers,
I've read a few posts and it looks like Gerald has already developed support for RSO's. In the previous emails shown below, I have code written for Hotine Oblique Mercators that uses the Michigan Georef Parameters. Hopefully the code you have written is more accurate. I could not get the Northing accurate enough. If you want the parameters for Michigan Georef they are available online if you google "Michigan Georef Projection". This projection is very important for any Michigan Proj users since most freely available data is provided in Michigan Georef. I think the last time I saw it in a proj format it was listed as a regular omerc which is not correct even though many sites describe it that way.
Anyhow, I was just wondering what the status was on the development of this projection
-Max Clever
Max,
OK, well implementing new projection methods is definately Gerald's area, not mine. So if you can interest him in it, then things should
be good. I just not competent to do it.
Best regards,
and watch the world go round - Rush | President OSGF, http://osgeo.org
-----Original Message-----
Sent: Tuesday, July 18, 2006 9:26 AM
To: 'Frank Warmerdam'
Cc: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: RE: [UMN_MAPSERVER-USERS] FW: Michigan Georef Projection Problems in Proj4
Frank,
First, to answer your question, the parameters Melita offered are not accurate enough and are not the true parameters of the Michigan Georef Projection. Also, the translation from EPSG to PROJ4 is not correct. I don't think Proj 4 supports a point azimuth method transformation for Hotine oblique Mercator (Rectified Skew Orthomorphic Projection)
Here is a link that contains the formulas for oblique mercator and Hotine Oblique Mercator (Michigan Georef is Hotine Oblique).
http://www.posc.org/Epicentre.2_2/DataModel/ExamplesofUsage/eu_cs34i.html
please note though, that in the forward case, I believe the small "v" should be computed using Log not natural log.
Also, if you want it for reference, below is the code of a couple of VB forms that I wrote 3 years ago with help from my professor in college to perform the forward and reverse cases. It is only accurate to about 7 cm in the Northing and 3 mm in the Easting when converting a point from Michigan Georef to Geographic and back. I think there must be some lack of precision in the code that is the reason for the accuracy problem. I hope this helps.
Const a = 6378137 ' semi major axis of the GRS80 ellipsoid
Const e2 = 0.0066943800229 ' eccentricity^2 of the GRS80 ellipsoid
Dim Pi As Double
Dim E As Double ' excentricity of the GRS80 ellipsoid
Public Function G2GREF(CoordIN() As Double) As Double()
Dim M1 As Double ' Paramter
Dim m2 As Double ' Paramter
Dim t1 As Double ' Paramter
Dim t2 As Double ' Paramter
Dim t0 As Double ' Paramter
Dim n As Double ' Paramter
Dim F As Double ' Paramter
Dim Eb As Double ' Paramter
Dim Nb As Double ' Paramter
Dim R As Double ' Paramter
MS_GeoRef = "Projection Oblique Mercator; Datum: NAD83; Ellipsoid: GRS80 " & vbCrLf & _
"Standard Units: Meters" & vbCrLf & _
"Origin = 86° 00' 00 W and 45° 18' 33 N" & vbCrLf & _
"Scale factor at projection's center: k= 0.9996" & vbCrLf & _
"Azimuth at center of projection: 337° 15' 20" & vbCrLf & _
"False Easting: 2546731.496, False Northing: -4354009.816"
Lon1 = -86# ' Longitude of projection's origin: 86° 00' 00" W
Lon1 = Lon1 * Pi / 180#
Lat1 = 45.30916666667 ' Latitude of projection's origin: 45° 18' 33" N
Lat1 = Lat1 * Pi / 180#
Az = 337.255555555556 ' Azimuth at center of projection: 337° 15' 20
Az = Az * Pi / 180#
SF = 0.9996 ' Scale factor at projection's center
Eb = 2546731.496 ' False Easting ( Eb = 528600.24)
Nb = -4354009.816 ' False Northing (Nb = 499839.834)
B = Sqr(1 + e2 * Cos(Lat1) ^ 4 / (1 - e2))
A1 = a * B * SF * Sqr(1 - e2) / (1 - e2 * (Sin(Lat1) ^ 2))
Temp = ((1 - E * Sin(Lat1)) / (1 + E * Sin(Lat1))) ^ (0.5 * E)
t0 = Tan(Pi / 4 - (Lat1) / 2) / Temp
D = B * Sqr(1 - e2) / (Cos(Lat1) * Sqr(1 - e2 * Sin(Lat1) ^ 2))
F = D + Lat1 / Abs(Lat1) * Sqr(D ^ 2 - 1) ' Eq. 4.110
E1 = F * t0 ^ B ' Eq. 4.111
G = 0.5 * (F - 1 / F) ' Eq. 4.112
Gamma0 = Isin(Sin(Az) / D) ' Eq. 4.113
Lon0 = Lon1 - Isin(G * Tan(Gamma0)) / B ' Lambda 0 at Eq. 4.114
U0 = (Lat1 / Abs(Lat1)) * (A1 / B) * Atn(Sqr(D ^ 2 - 1) / Cos(Az))
V0 = 0
LatIN = DMS2R(CoordIN(1))
LonIN = DMS2R(CoordIN(2))
Temp = ((1 - E * Sin(LatIN)) / (1 + E * Sin(LatIN))) ^ (0.5 * E)
t = Tan(Pi / 4 - (LatIN) / 2) / Temp ' Eq. 4.117
Q = E1 / (t ^ B)
S = 0.5 * (Q - 1 / Q)
Tc1 = 0.5 * (Q + 1 / Q)
V1 = Sin(B * (LonIN - Lon0))
U1 = (-V1 * Cos(Gamma0) + S * Sin(Gamma0)) / Tc1
vl = A1 * Log((1 - U1) / (1 + U1)) / (2 * B)
temp1 = (S * Cos(Gamma0) + V1 * Sin(Gamma0)) / Cos(B * (LonIN - Lon0))
ul = (A1 / B) * Atn(temp1)
x = vl * Cos(Az) + ul * Sin(Az) + Eb
y = ul * Cos(Az) - vl * Sin(Az) + Nb
ReDim Preserve CTemp(1 To 2) As Double
CTemp(1) = x
CTemp(2) = y
G2GREF = CTemp
End Function
Public Function GREF2G(CoordIN() As Double) As Double()
Dim PhiOut As Double ' Paramter
Dim LonOut As Double ' Paramter
Lat1 = 45.309166666667 ' Latitude of projection's origin: 45° 18' 33" N
Az = Az * Pi / 180#
ttemp = e2 * (Cos(Lat1) ^ 4) / (1 - e2)
B = Sqr(1 + ttemp)
A1 = a * B * SF * Sqr(1 - e2) / (1 - e2 * (Sin(Lat1)) ^ 2)
Temp = ((1 - E * Sin(Lat1)) / (1 + E * Sin(Lat1))) ^ ( 0.5 * E)
ttemp1 = Cos(Lat1) * Sqr(1 - e2 * (Sin(Lat1)) ^ 2)
D = B * Sqr(1 - e2) / ttemp1
xIN = CoordIN(1)
yIN = CoordIN(2)
'Actual Computations for Reverse case Hotine Oblique Mercator
xr = xIN - Eb
yr = yIN - Nb
vs = xr * Cos(Az) - yr * Sin(Az)
us = yr * Cos(Az) + xr * Sin(Az)
temp1 = -B * vs / A1
Qp = (2.71828182845905) ^ temp1
Sp = 0.5 * (Qp - 1 / Qp)
Tp = 0.5 * (Qp + 1 / Qp)
Vp = Sin(B * us / A1)
Up = (Vp * Cos(Gamma0) + Sp * Sin(Gamma0)) / Tp
temp2 = (1 + Up) / (1 - Up)
t = (E1 / Sqr(temp2)) ^ (1 / B)
PhiOut = Pi / 2 - 2 * Atn(t)
'Iterative Solution for Phi Out
' For i = 1 To 30
' Temp = ((1 - E * Sin(PhiOut)) / (1 + E * Sin(PhiOut))) ^ ( 0.5 * E)
' PhiOut = Pi / 2 - 2 * Atn(t * Temp)
' Next i
'Single Line Solution for Phi Out
PhiOut = PhiOut + Sin(2 * PhiOut) * (e2 / 2 + (5 * e2 ^ 2) / 24 + (e2 ^ 4) / 12 + (13 * e2 ^ 6) / 360) + Sin(4 * PhiOut) * ((7 * e2 ^ 2) / 48 + (29 * e2 ^ 4) / 240 + (811 * e2 ^ 6) / 11520) + Sin(6 * PhiOut) * ((7 * e2 ^ 4) / 120 + (81 * e2 ^ 6) / 1120) + Sin(8 * PhiOut) * ((4279 * e2 ^ 6) / 161280)
temp3 = (Sp * Cos(Gamma0) - Vp * Sin(Gamma0)) / Cos(B * us / A1)
LonOut = Lon0 - Atn(temp3) / B
CTemp(1) = r2dms(PhiOut)
CTemp(2) = r2dms(LonOut)
GREF2G = CTemp
End Function
From: Frank Warmerdam [mailto:fwarmerdam at gmail.com] On Behalf Of Frank Warmerdam
Sent: Saturday, July 15, 2006 10:01 PM
To: Clever, Max
Subject: Re: [UMN_MAPSERVER-USERS] FW: Michigan Georef Projection Problems in Proj4
Clever, Max wrote:
> Hi,
> Did anyone see this the last time I sent it? It relates to Mapserver as
> well since Mapserver uses Proj4 for its projections.
Max,
I have skimmed this material, but frankly I'm not sure what action item
there is, and I find myself with limited time for work on PROJ.4.
Is the problem that the parameters Melita offered a couple years ago
aren't accurate enough? Or that the underlying translation from EPSG
to PROJ.4 wasn't fixed so the epsg file keeps getting regenerated
wrong? If it is a tranlation problem, then that is basically something
I ought to fix. But I basically need some formulation to recognise
a distinct oblique mercator case for the michigan projection from the
EPSG codes (or parameters), and what that should map to in WKT format,
and in PROJ.4 format. I'm happy to use the ESRI WKT representation if
there isn't an obvious existing form for this special case.
If you can walk me through what should be changed, I'm willing to work
on it.
Best regards,
> Two years ago, I ran into a problem with the Michigan Georef Projection
> and the way that proj identified it. I had sent emails back and forth
> for a while until someone sent a temporary solution of providing false
> parameters that worked.. *for the most part*. This temporary solution,
> of course, did not actually solve the problem, but instead delayed the
> fixing of the methods that proj identifies projections and translates
> them. For that I am sorry for not remaining vigilant in seeing a true
> solution being devised. But now, since I have just now installed the
> latest version of GRASS 6.1, I have come full circle and face this
> problem again. To provide a quick access to the background of what has
> already been said on this projection please note the previous emails
> below. I believe, at this time still, that the *omerc* projection and
> its parameters as used by proj cannot correctly describe or transform a
> omerc projection with a "natural origin". From what I understand,
> Hotine oblique mercator and Rectified Skew Orthomorphic are one and the
> same or depend on where the skew is corrected. Has there been a
> solution determined for this projection? If not, maybe a solution to
> this problem would be to have Proj have oblique mercators split between
> "natural origins" and cartesian center point origins. I hope, maybe,
> someone has been looking at this lately but I doubt it. Any comments or
> solutions would be very welcome. Thanks.
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20060720/850d84aa/attachment.html>
More information about the Proj
