[Proj] How to Scale a Mercator projection?
Frank Warmerdam
warmerdam at pobox.com
Tue Jul 25 13:48:37 PDT 2006
Christopher Barker wrote:
> Hi all,
> I'm trying to figure out how to do a Mercator projection. I think I've
> got how it's supposed to work, but I can't get the scale parameter to do
> anything at all. On the proj4 command, it's either k=scale or k_0-scale,
> neither does anything. Also, according to the docs:
Christopher,
I'm sorry I haven't responded yet to any of your email on gdal-dev and
elsewhere. I have just checked, and I definately see an effect when
specifying +k_0:
warmerda at gdal2200[82]% proj +proj=merc +ellps=WGS84 +k_0=0.998
5 5 (input)
555484.26 552476.68 (output)
warmerda at gdal2200[83]% proj +proj=merc +ellps=WGS84 +k_0=1.0
5 5 (input)
556597.45 553583.85 (output)
Perhaps you could be more specific about how you determined it was having
no effect?
> A more common formulation for Mercator is to drop the +k_0, and instead
> to provide a latitude of true scale using the +lat_ts parameter, which
> is the latitude at which the scale is 0
Where exactly did you see this? You are quite right that a scale of zero
is nonsensical.
Hopefully I'll have a chance to respond on the BSB issues on gdal-dev.
Best regards,
and watch the world go round - Rush | President OSGF, http://osgeo.org
More information about the Proj
