[Proj] libproj.so.0 problem
Hamish
hamish_nospam at yahoo.com
Tue Jun 6 03:07:20 PDT 2006
"Jaime Lopez" <jalopcar at gmail.com> wrote:
> I have installed GRASS 6.0.2 with linux mandrake 10.0 and proj.4.4.8,
> but I got this problem
> "Error in startup script: ps.map:error while loading shared libraries:
> libproj.so.0: cannot open shared object file: No such file o directory
either:
add /usr/local/lib to /etc/ld.so.conf and run ldconfig
or
locate libproj.so
ln -s /where/it/was/libproj.so /usr/local/lib/libproj.so.0
if /usr/local/ is in /etc/ld.so.conf or libproj.so.0 is in /usr/lib/
then I don't know.
For futher help try the grass user-list as I don't think this one is
proj's fault.
Hamish
More information about the Proj
