[Proj] Method to use for getting a set of projections added tothe EPSG code list.
Kralidis,Tom [Burlington]
Tom.Kralidis at ec.gc.ca
Tue Jun 6 09:26:23 PDT 2006
> Bob Basques wrote:
> > All,
> > I was forwarded to this list because of a need to add in some
> > Projections to the EPSG list.
> > I would like to have added the seperate County Projections for the
> > State
> > of Minnesota.
> > What procedures need to be followed to get something like
> this moving
> > ahead?
> Bob,
> You can extend your local proj.4 'epsg' translation file as
> you wish. However, the original EPSG database is not under
> our control so if you want the county projections added to
> the core EPSG database you will need to contact the OGP
> Surveying and Positioning Committee.
> http://www.epsg.org/
> I am not keen on adding non-EPSG approved codes into the
> PROJ.4 epsg translation file.
Bob,
You might also want to chat with CubeWerx (http://www.cubewerx.com/),
who holds the 42xxx slotsof EPSG; they may be an easier and more
expedient approach.
..Tom
More information about the Proj
