[Proj] gdalwarp and proj.4
Mateusz Loskot
mateusz at loskot.net
Wed Jun 14 02:15:10 PDT 2006
Hamish wrote:
> if you have /usr/local/lib/libproj.so
> but it just doesn't work, check that "/usr/local/lib/" is listed in
> /etc/ld.so.conf
> If it isn't, add it to the end of that file and then run ldconfig as
> root.
To Gary:
Also, after those steps above, check if ldconfig sees this PROJ's library:
$ ldconfig -p | grep libproj
Cheers
Mateusz Loskot
http://mateusz.loskot.net
More information about the Proj
