[Proj] gdalwarp and proj.4
gary lists at lazygranch.com
Sun Jun 18 07:26:28 PDT 2006
It took a symbolic link, though not that one. I guess every build of
GRASS is a slightly different. For Suse 10.0, this was needed.
ln -s /usr/lib/libproj.so.0.5.0 /usr/local/lib/libproj.so
Jaime Lopez wrote:
> Hi Gary,
> I could fix that problem this way, you must write :
> ln -s /usr/local/ /usr/local/bin
> this make a link with the file libproj.so
> I hope this helps you,
> Jaime Lopez
> 2006/6/13, gary <g at lazygranch.com <mailto:g at lazygranch.com>>:
>     I'm running gdalwarp and getting the error message
>     ERROR6: Unable to load PROJ.4 library (libproj.so) ...
>     Any clues how to fix this?
>     _______________________________________________
>     Proj mailing list
>     Proj at lists.maptools.org <mailto:Proj at lists.maptools.org>
>     http://lists.maptools.org/mailman/listinfo/proj
> Jaime Lopez
> Proj mailing list
