[Proj] cs2cs for datum conversion and the "towgs84" parameter
Gerald I. Evenden
gerald.evenden at verizon.net
Sun Jun 18 13:14:16 PDT 2006
On Sunday 18 June 2006 12:31 pm, Hyer, Dr. Edward (Post Doc) wrote:
> Hi,
> I got involved with this because I received some imagery in plate-carree
> projection which used the SAD69 datum. Interestingly, while ENVI claims to
> support this projection, IDL does not, which is odd since they are supposed
> to be the same product. For my application, I am working with a large list
> of points for which I need imagery values, so IDL was my choice, and I
> found I could do the datum conversion with a shell script using cs2cs.
Within standard proj/libproj system, Plate-Carree is referred to a Equidistant
Cylindrical or +proj=eqc. There are many names for this projection with some
based upon specifying a latitude of true scale.
> Googled, googled, googled, someone must have done this before. And found
> different solutions: 1) 'cs2cs +proj=latlong +datum=WGS84 +to
> +proj=latlong +ellps=GRS67 +towgs84=-57,1,-41,0,0,0,0 +no_defs -f "%.5f"
I do not believe you did a projection in the above, just a geographic
coordinate to geographic coordinate conversion while shifting datums. If
+proj=eqc were selected it is only in spherical form so selecting +ellps=xxx
only means that the major axis (a) of xxx is used as radius of the sphere.
> -w5 ' 2) People who were dealing with UTM coordinates had a different value
> for +towgs84 : 75,1,44 3) This guy's doctoral dissertation (in Portuguese)
> (http://www.teses.usp.br/teses/disponiveis/3/3138/tde-06122002-115813/publi
>co/03capitulo02.pdf) claims that SAD69 to WGS84 is nothing but a shift of
> -66.87 meters X, +4.37 meters Y, -38.52 meters Z. He also states that this
> is by Presidential Decree. Is this like the "pi=3" thing here in the
> States?
I feel that confusion of the above is related to persistant lack of
documentation/education that will separate the concepts of projections and
datum shifts. But, alas, I am beating an old drum. Sorry.
> The error with getting the datum conversion wrong is below the resolution
> of any of my data sets, so I don't have easy ways to check my conversion.
> However, since my project here is actually about the consequences of this
> poor spatial resolution, I think I should try and get it right. Can someone
> help?
> Obrigado antes,
> Dr. Edward J. Hyer
> Post-Doctoral Researcher
> Naval Research Laboratory
> Marine Meteorology Division
> 7 Grace Hopper Avenue, Stop 2
> Monterey, California 93940
> 831-656-4023
> FAX 831-656-4769
> edward.hyer at nrlmry.navy.mil
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
Jerry and the low-riders: Daisy Mae and Joshua
"Cogito cogito ergo cogito sum"
Ambrose Bierce, The Devil's Dictionary
More information about the Proj
