[Proj] Re: Discovery: libproj4 stmerc = French Gauss-Laborde projection
Strebe at aol.com Strebe at aol.com
Mon Jun 26 22:36:24 PDT 2006
 gerald.evenden at verizon.net writes:
(Original e-mail in full at the end.)
> The cusps at the ends of the equator seem unnatural.
> The cusps at the ends of the equator sure look like violations of
> conformality
> to me.
Do the cusps on the August epicycloidal or the Eisenlohr seem unnatural? If
so, do you believe those projections are not really conformal? If not, then
what do you think the difference is?
The position of the cusps is directly related to the eccentricity -- in fact,
the relationship is surprisingly simple:
Longitude of cusp = (pi/2) * (1 - e) radians
The spherical form is infinite because the cusp is at the pole... which
projects to infinity. The greater the eccentricity, the closer to the prime
meridian starts the cusps, and the stubbier the map.
> Also, why does both of the other procedures that
> we have looked at all contain discontinuities at the limits
Why is 1 - sqrt (1 - k) when k approaches zero ill-conditioned when computed
as is, but marvelously well-behaved when computed as a series? The question is
not the mathematics of the projection. We're talking about the same
projection, whether Dozier, Kruger, or Wallis. The question is only how the projection
is formulated. Wallis's formulation avoids poor conditioning. They all express
the same underlying mathematics.
> And a remaining note: this projection has not been published in an any
> cartographic journal and has not been subject to normal peer review nor the
> review of subsequent readers.
I think you mean to say that Wallis' formulation has not been published.
Obviously the projection has, by any number of people over nearly two centuries.
> What magic twist
> allows Wallis to come up with the above map when all others want to extend
> to
> infinity?
You are misundertanding the problem. The others don't "want" to extend to
infinity; their accuracy simply degrades into uselessness.
> Is it truly a normal transverse mercator where the scale factor is
> 1. along the central meridian?
Yes.
> Has that been checked?
Yes, empirically, and yes, analytically.
> Sorry, I am still a
> skeptic until I see the math and a functional program that can demonstrate
> the conformal properties of the projection.
You might avail yourself of a copy of L.P. Lee's monograph, "Conformal
Projections Based on Elliptic Functions", Cartographica, Monograph Number 16, 1976.
Quoting verbatim from p. 97:
"The positive y-axis represents part of the equator, extending from lambda =
0 to lambda = (pi/2)*(1-k)... At this point the equator changes smoothly from
a straight line to a curve... The projection of the entire spheroid is shown
in Fig. 46, again using the eccentricity of the International (Hayford)
Spheroid. It can be seen that the entire spheroid is represented withing the finite
area without singular points..."
If you will take your attention to page 99, you will see a rendition of the
(only true) transverse Mercator projection for the ellipsoid, generated by
means of Thompson's 1945 formulation, succeeding across the entire ellipsoid
because Lee (or someone) took the time to reformulate the problematic regions to
make them suitable for calculation. The diagram is indistinguishable from the
one I posted online and drew using Wallis's formulation.
Dozier seems to follow the formulation of Thompson, more or less, which is
probably why it runs into trouble at the extremes and is certainly why it's more
complicated than necessary. Wallis solves the boundary condition in a
different way. It's not without its problems; you need to find a root which, for
arbitrary eccentricities, defies any formulaic seed value. Nonetheless that can be
solved efficiently in most cases and merely solved in all cases. There are
one or two places where one must be careful of numeric techniques, like many
other projections.
Regards,
-- daan Strebe
In a message dated 6/26/06 13:22:06, gerald.evenden at verizon.net writes:
> On Wednesday 14 June 2006 1:12 am, Strebe at aol.com wrote:
> > You might contact Dr. David E. Wallis. He devised a much simpler method
> > than Dozier's. I've implemented it for the full-ellipsoid. You can see a
> > plot of an earth-like ellipsoid here:
> http://mapthematics.com/Projection%20Images/Cylindrical/Transverse%20Mercat
> >or. GIF
> > The method works for arbitrary eccentricities. Contact me privately if
> > you're interested. Since it is Dr. Wallis's invention, I'll put you in
> > contact with him.
> I wrote to the address on the web site but letter was returned
> undeliverable.
> I suspect that the web page is several years old and not maintained.
> Not to beat a dead horse of several years ago, I have stared at the above
> gif
> and it still bothers me and it does not seem real.  The cusps at the ends of
> the equator seem unnatural.  Also, why does both of the other procedures
> that
> we have looked at all contain discontinuities at the limits---most commonly,
> they require isometric latitude which fails at 90 degrees.  What magic twist
> to
> infinity?  Is it truly a normal transverse mercator where the scale factor
> is
> 1. along the central meridian?  Has that been checked?  Sorry, I am still a
> conformality
> to me.
> As previously noted, the French TM has been added to libproj4 and the Dozier
> procedure has also been pretty well conquered and will be add to
> libproj4---probably as dtmerc.  Neither of these routines will do |lat|=90
> nor |lon|=90.
> Jerry and the low-riders: Daisy Mae and Joshua
> "Cogito cogito ergo cogito sum"
>    Ambrose Bierce, The Devil's Dictionary
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20060627/c6ea5bee/attachment.html>
