[Proj] Complex Transverse Mercator
Oscar van Vlijmen
ovv at hetnet.nl
Wed Jun 28 13:33:42 PDT 2006
> From: "Gerald I. Evenden"
> I strongly do not believe any of these new extended TMs should be use for UTM
> as the "standard UTM" is defined as the taylor expansion---warts and all.
> Anyone who has abused the limits of UTM will have trouble when using new
> versions. Secondly, UTM is bound by "law" to the limits of +-3.5 degrees so
> these extensions are immaterial.
>From my memory: wasn't the definition 3 degrees with an overlap of 40
kilometers? Is about the same, but legally different.
> As per my comments three years ago, none of this make any intuitive sense.
> This probably explains why the German web page deviates as one approaches
> pi/2.
> BTW, how do these numbers stack up with the German web page.
If this is about Schuhr's web calculator after Klotz, located at:
<http://gauss.fb1.fh-frankfurt.de/cgi-bin/cgi_gk?modus=intro>
then I can only repeat:
This calculator suffers from the usual problems at low latitudes coupled
with large longitude differences with CM.
[more details including numbers replied to mr. Evenden personally. Let me
know if you're interested in the numbers].
More information about the Proj
