[Proj] Re: Complex Transverse Mercator
Strebe at aol.com
Strebe at aol.com
Thu Jun 29 18:55:52 PDT 2006
The values in the table below agree with my calculations based on Wallis,
down to millimeter precision. It's a fine validation of both methods.
Regards,
-- daan Strebe
In a message dated 6/27/06 10:40:04, ovv at hetnet.nl writes:
> From: Strebe-aol.com:
> You might avail yourself of a copy of L.P. Lee's monograph, "Conformal
> Projections Based on Elliptic Functions", Cartographica, Monograph Number
> 16, 1976. Quoting verbatim from p. 97:
> "The positive y-axis represents part of the equator, extending from lambda =
> 0 to lambda = (pi/2)*(1-k)... At this point the equator changes smoothly
> from a straight line to a curve... The projection of the entire spheroid is
> shown in Fig. 46, again using the eccentricity of the International
> (Hayford) Spheroid. It can be seen that the entire spheroid is represented
> withing the finite area without singular points..."
> Reply:
> Thanks for this explanation!
> The numbers show it too:
> International ellipsoid:
> 90*(1-eccentricity) = 82.62073 decimal deg
> Tranverse Mercator:
> lat0=0; lon0=0; x0=5e5; y0=0; k0=0.9996;
> // International ellipsoid
> lat=0; lon=82.50; x,y = 18712722.276, 0 meters
> lat=0; lon=82.60; x,y = 18840409.942, 0
> lat=0; lon=82.61; x,y = 18853673.034, 0
> lat=0; lon=82.62; x,y = 18867090.964, 0
> lat=0; lon=82.621; x,y = 18868446.553, 0.2947
> lat=0; lon=82.63; x,y = 18880722.285, 107.602
> lat=0; lon=82.64; x,y = 18894438.954, 366.186
> lat=0; lon=82.65; x,y = 18908216.295, 738.078
> lat=0; lon=82.70; x,y = 18977788.411, 3947.057
> lat=0; lon=82.80; x,y = 19119409.657, 15745.905
> For what it's worth: alculated with my improved version of 'Dozier'.
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20060629/397bcc2d/attachment.html>
More information about the Proj
