[Proj] help with clark66 as datum
Martin Vermeer
martin.vermeer at hut.fi
Fri Mar 10 10:19:20 PST 2006
On Fri, Mar 10, 2006 at 09:30:27AM -0600, Clifford J Mugnier wrote:
> The DCW - Digital Chart of the World was HAND digitized by the Defense
> Mapping Agency in the early 80s from small scale "ONC" Operational
> Navigation Charts. That became the defacto FREE dataset of the world's
> coastlines, rivers, etc used by all software companies including ESRI. (It
> came on a 9-Track tape from DMA as did the GCTP come on a 9-track tape from
> the U.S. Geological Survey.) The ellipsoid used as a default then was the
> Clarke 1866. That is how it wound up being used for New Zealand. (So was
> the entire world.)
> You have to be old enough to be able to remember this stuff!
Does this perhaps relate to the global coastline file 'ciakyst' ("CIA
coast") that I used in Denmark in the late 80s for plotting geoid maps?
- Martin
Name: not available
Desc: not available
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20060310/f915b34e/attachment.sig>
More information about the Proj
