[Proj] MGRS/USNG support?
Duncan Agnew dagnew at ucsd.edu
Thu May 4 12:46:35 PDT 2006
I've made this point before, but again: MGRS and other location codes
are different things from
the coordinates PROJ works with. The coordinates describe a point, the
codes describe an area
(to variable precision depending on code length).
Not to say there wouldn't be room for a separate routine that converted
UTM zone, E, and N, to
MGRS or equivalent (there is no reverse mapping)--but it should be
separate.
Duncan Agnew
