[Proj] Re: value of PROJ_LIB variable
Erich Sadlowski
erich.sadlowski at gmx.de
Mon May 8 21:32:41 PDT 2006
Frank Warmerdam <warmerdam <at> pobox.com> writes:
> I am not aware of anywhere in PROJ.4 that sets this enviroment variable. But
> PROJ.4 does have a few methods of finding the support files beside this
> environment variable.
> A default build on Unix-like systems will define the PROJ_LIB macro to be the
> default install directory in pj_open_lib.c. This is often
> /usr/local/share/proj.
Hello Frank,
Thanks for your answer!
Yes, in the meantime I found out, that the variable is set in the (generated)
Makefile and transfered to the library via the "-D" define flag.
Now I use your suggested pj_set_searchpath() and it works fine.
Again: Thanks a lot!
Best regards
Erich
More information about the Proj
