[Proj] reproject batch command
Eric Miller
EMiller at dfg.ca.gov
Wed May 17 08:08:53 PDT 2006
In the contrib directory for Frank's shapelib is a utility called "shpproj" which supposedly will reproject a single shapefile. You'd have to build it; the "shpproj.c" file has a command line for GCC in the comments near the top. To batch it, you'd need to write a shell script or some other kind of script. No idea if the program works correctly...
>>> zhonghaiw at gmail.com 5/17/2006 5:34 AM >>>
Hi All,
I have a subfolder with ESRI shapefiles, and now I want to reproject the
shapefile, are there any batch commands to do this?
thanks in advance
zhonghai
17.05.2006
More information about the Proj
