[Proj] Proj4 transform from WGS84 to UK Northings and Eastings help needed ...
Penny Bamborough pennyb at btex.co.uk
Tue May 23 06:24:18 PDT 2006
Hiya all
I have some Navteq data, which I believe is in WGS84 decimal degrees.
I am using an ESRI product (which uses proj4) to project the data
into british national grid northings and eastings. However, when I
project the data, the coordinates appear to be between 100 to 200m
out from where I would expect. I use the following settings for the
proj4 translation:
proj=tmerc
a=6378137.0
b=6356752.3141
k_0=0.9996012717
ellps=airy
lat_0=49d0n
lon_0=2d0w
x_0=400000
y_0=-100000
Would anyone have any suggestions as to why we receive this position
offset error ?
Penny
