[Proj] Re: Proj Digest, Vol 24, Issue 15
Melita Kennedy mkennedy2 at earthlink.net
Tue May 23 20:05:37 PDT 2006
-----Original Message-----
Date: Tue, 23 May 2006 08:24:50 -0700
Subject: Re: [Proj] Proj4 transform from WGS84 to UK Northings and
	Eastings help needed ...
To: <proj at lists.maptools.org>
I'd be surprised if any ESRI product used PROJ.4.  They've been pretty adamant that
their projection libraries are not based on PROJ.4.
>>> pennyb at btex.co.uk 5/23/2006 6:24:18 AM >>>
Hiya all
I have some Navteq data, which I believe is in WGS84 decimal degrees.
I am using an ESRI product (which uses proj4) to project the data
[snip]
As far as I know, we aren't, or at least, no one's asked me about it. Software that we've
acquired might be using PROJ.4, rather than the in-house projection enigne library, and
there are a few other instances where something else is being used (ArcInfo workstation,
ArcView GIS, MapObjects Java) but I know it's not PROJ.4.
Melita Kennedy
ESRI Product Specialist
