[Proj] conversion latlong to UTM (& vice versa)
oon at informatika.org oon at informatika.org
Thu Nov 2 01:22:44 PST 2006
Dear All Proj user,
I want to convert coordinate with datum WGS84, from latlong projection
to UTM projection
(and vice versa).
If I convert from latlong projection to UTM projection,
I can get the UTM zone from UTM definition, so I can calculate the zone
from it's longitude.
If I'm doing vehicle tracking with UTM projection,
and the vehicle moving between UTM zones,
How should I do to get UTM zone of current position of vehicle?
(so I can convert UTM to latlong again).
Is it any statement or definition of UTM that declare
how to get UTM Zone from UTM coordinate?
Is it any Proj utilities (function/procedure) that support my problem?
thanks,
regards,
Oon Arfiandwi M.
