[Proj] cs2cs - epsg codes DD.mm.ss to DD.mm.ssss
Wed Nov 8 07:36:52 PST 2006
Mike D'Ambrogia wrote:
> Need to use cs2cs to convert degrees.minutes.seconds to
> degrees.minutes.milliseconds, dug thru the epsg file but nothing jumps
> out at me. Can someone point me to the epsg codes for these formats?
MikeD,
First, PROJ.4 definately does not support a deg.min.millisecond form.
I scanned the EPSG angular units of measures codes (91xx) and didn't
see anything that looked like what you want.
I have attached the EPSG units of measure table as an EPSG if you want
to dig through it in yourself.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
Type: text/x-comma-separated-values
Desc: not available
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20061108/4b91be5e/attachment.bin>
