[Proj] State-wide projection for Italy?
Clifford J Mugnier
cjmce at lsu.edu
Fri Nov 17 09:03:29 PST 2006
Markus,
I suggest you consider an oblique Mercator, preferably the Hotine Rectified
Skew Orthomorphic (RSO).
Cliff Mugnier
LSU
in Italy the Gauss-Boaga system is commonly used besides UTM.
Both systems aren't appropriate for state-wide mapping of
Italy since both of them are splitting the country into
two zones.
Seeking around, I could not identify a recommended projection
to be used for all-Italy maps.
I would be grateful to receive suggestion(s).
Kind regards
Markus Neteler
Proj mailing list
Proj at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/proj
More information about the Proj
