[Proj] pj_transform function
Hugo Tyson
Hugo.Tyson at cpslocates.com
Fri Oct 6 01:38:01 PDT 2006
proj-bounces at lists.maptools.org <> wrote:
> I want to transform ... this lat/lon 39.739/-104.985...
> to world mercator project ..with the defintition
> World Mercator <54004> +proj=merc +latts=0 +lon0=0
> +k=1.000000 +x0=0 +y0=0 +ellps=WGS84 +datum=WGS84 +units=m no_defs <>
> but the method gives an "error"....
> this method works fine if i give lat/lon say 42.4182,-74.2643
I've not heard of "world mercator", but looking at the parameters
it's projecting into a plane tangent to the sphere at lat 0, lon 0.
So it only works for longitudes from -90 to +90 (though these map
to infinities in the projected plane).
Your example of -104 longitude is around the back of the earth,
on the "far side" from the projection plane. Therefore a
line from the origin through the point never intersects the
projection plane, so no result can be calculated. Hence your
error. Lon -74 is in range, so it's OK.
HTH,
- Huge
Hugo Tyson, Cambridge Positioning Systems Ltd
This email and any attachments are confidential. They have been checked for viruses but it is your
responsibility to conduct your own virus checks.
Cambridge Positioning Systems Limited, 62-64 Hills Road, Cambridge, CB2 1LA, is registered in England
under company number 2808344.
More information about the Proj
