[Proj] pj_transform function
Fri Oct 6 08:03:06 PDT 2006
Sandeep Kumar Jakkaraju wrote:
> Hi All
> I want to transform ... this lat/lon 39.739/-104.985...
> to world mercator project ..with the defintition
> World Mercator <54004> +proj=merc +latts=0 +lon0=0 +k=1.000000 +x0=0
> +y0=0 +ellps=WGS84 +datum=WGS84 +units=m no_defs <>
>  but the method gives an "error"....
> this method works fine if i give lat/lon say 42.4182,-74.2643
> can some one help me ... Doesnt this pj_transform always work !!!
Sandeep,
I expect the problem has to do with axis order.  By default proj
expects geographic locations in "longitude latitude" order.  So
you need to pass -104.985 39.729.
If -104 is treated as a latitude it will be beyond the legal range
(-90 to 90).
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
