[Proj] OSTN02 question: GRS80 instead of Airy.
Roger Oberholtzer roger at opq.se
Wed Oct 25 03:58:14 PDT 2006
I use the C API to do transformations. I am converting from GPS values
in WGS84 to OSTN02 for the United Kingdom. My current code is:
       fromProj = pj_init_plus(
                "+proj=latlong "
                "+ellps=WGS84 "
                "+towgs84=0,0,0 "
                "+nodefs")
        toProj   = pj_init_plus(
                "+proj=tmerc "
                "+lat_0=49 "
                "+lon_0=-2 "
                "+k=0.9996012717 "
                "+x_0=400000 "
                "+y_0=-100000 "
                "+ellps=airy "
                "+nadgrids=gb.gsb "
                "+units=m "
                "+no_defs")
Note that I do a grid shift, using data provided by a kind member of
this list.
My question is, how can I use the GRS80 ellipsoid instead of Airy?
Roger Oberholtzer
OPQ Systems AB
Ramböll Sverige AB
Kapellgränd 7
P.O. Box 4205
SE-102 65 Stockholm, Sweden
Tel: Int +46 8-615 60 20
Fax: Int +46 8-31 42 23
