[Proj] Re: new 7 parameters
massimodisasha
massimodisasha at yahoo.it
Wed Oct 25 20:23:41 PDT 2006
wow !
great!
this is what i need :-) ,
thanks for your help !!!
Massimo.
Il giorno 23/ott/06, alle ore 18:02, proj-request at lists.maptools.org
ha scritto:
> On Sat, Oct 21, 2006 at 07:41:47PM +0200, massimodisasha wrote:
>> hi,
>> i've 45 point of the (igm95) national italian grid of double points
>> in (wgs84 - gauss boaga R40)
>> (IGM is the italian's geographical military institute)
>> all my points are distribuited in a small italian region.
>> i've done a little algoritms in matlab language for resolve the
>> Helmert linear sistem....
>> ...now i've a new set of 7 parameters for do a trasformation beetween
>> WGS and GB-R40.
>> how can i use this new parameters in Grass ?
> When you define a new "location" (GRASS project), then
> select
> D Other projection
> to go into the user defined dialog.
> Then select
> Please specify projection name
> Enter 'list' for the list of available projections
> Hit RETURN to cancel request
>> tmerc
> Do you wish to specify a geodetic datum for this location?(y/n) [y]
> Please specify datum name
> Enter 'list' for the list of available datums
> or 'custom' if you wish to enter custom parameters
>> custom <<<<--- !!
> Please specify ellipsoid name
> Enter 'list' for the list of available ellipsoids
>> international
> Please specify datum transformation parameters in PROJ.4 syntax.
> Examples:
> towgs84=dx,dy,dz (3-parameter transformation)
> towgs84=dx,dy,dz,rx,ry,rz,m (7-parameter transformation)
> nadgrids=alaska (Tables-based grid-shifting transformation)
>> towgs84=-104.1,-49.1,-9.9,0.971,-2.917,0.714,-11.68
> Parameters to be used are:
> "towgs84=-104.1,-49.1,-9.9,0.971,-2.917,0.714,-11.68"
> Is this correct?(y/n) [y]
> Enter Scale Factor at the Central Meridian [1.0000000000]: 0.9996
>> can i use it in the (r.proj/v.proj) grass command?
> Like this r.proj/v.proj use the datum.
> Shortcut: If you want to modify an existing location (not
> sure if that's a good idea since your data need to be reprojected),
> simply edit
> grassdata/<location>/PERMANENT/PROJ_INFO
> and substitute the old datum parameters with
> datum: rome40
> datumparams: towgs84=-104.1,-49.1,-9.9,0.971,-2.917,0.714,-11.68
> My PROJ_INFO looks like this:
> datum: rome40
> proj: tmerc
> ellps: international
> a: 6378388.0000000000
> es: 0.0067226700
> f: 297.0000000000
> lat_0: 0.0000000000
> lon_0: 9.0
> k_0: 0.9996000000
> x_0: 1500000.0000000000
> Hope this helps,
> Markus
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20061026/c703ba17/attachment.html>
More information about the Proj
