[Proj] cs2cs with WGS72
Frank Warmerdam
warmerdam at pobox.com
Wed Sep 6 12:52:33 PDT 2006
Naiara Pinto wrote:
> Hi all,
> I am trying to use cs2cs to go from Lambert Azimuthal Equal Area to
> Lat Long. I get a problem when I try to use the WGS72 datum:
>> cs2cs +proj=laea +ellps=sphere +lat_0=45 +lon_0=-100 +x_0 =0 +y_0=0
> +to +proj=latlong +datum=WGS72 -r <<EOF
>> 0 0
>> EOF
> Using to definition: proj=latlong datum=WGS72
> Rel. 4.4.9, 29 Oct 2004
> <cs2cs>:
> projection initialization failure
> cause: unknown elliptical parameter name
> program abnormally terminated
> This works fine with WGS84 and NAD83. Does anyone have any ideas why
> this happens?
Naiara,
There is no PROJ.4 recognise datum called WGS72 (use cs2cs -ld to see
show short list of built in datum names). Instead you can just use the
WGS72 ellipsoid with no other datum modifiers.
eg.
+proj=latlong +ellps=WGS72
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
More information about the Proj
