[Proj] Reversible Calculation? (cs2cs) <-- syntax mistake (-r)
oon at informatika.org
Tue Sep 12 22:53:57 PDT 2006
I found the answer about my previous coordinate transformation not
reversible, because syntax mistake of cs2cs.
In the reverse calculation i shouldn't use -r
minnie:~/proj4/bin oon$ ./cs2cs -r +proj=latlong +datum=WGS84 +to
+proj=utm +datum=WGS84 +zone=47
3d30'17.47"N 98d36'27.58"E
456423.28 387405.51 0.00
25'32.12N 101d26'29.35"E
771751.63 47083.39 0.00
^C
minnie:~/proj4/bin oon$ ./cs2cs +proj=utm +datum=WGS84 +zone=47 +to
456423.28 387405.51
98d36'27.58"E 3d30'17.47"N 0.000
101d26'29.35"E 0d25'32.12"N 0.000
^C
thanks.
regards,
Oon Arfiandwi
Quoting Eric Miller <EMiller at dfg.ca.gov>:
> You've mixed up your X's and Y's in the reverse calculation.
> C:\>cs2cs +proj=latlong +datum=WGS84 +to +proj=utm +datum=WGS84
> +zone=47
> C:\>cs2cs +proj=utm +datum=WGS84 +zone=47 +to +proj=latlong
> +datum=WGS84
> 456423.28 387405.51
> 387405.51 456423.28
> 97d59'8.086"E 4d7'43.261"N 0.000
>>>> oon at informatika.org 9/12/2006 5:27:40 AM >>>
> Dear All Proj Users & Developers,
> I've tried to convert from WGS84 to UTM (zone 47) with cs2cs:
> minnie$ ./cs2cs -v +proj=latlong +datum=WGS84 +to +proj=utm
> +datum=WGS84 +zone=47 -r +units=m << EOF
>> EOF
> # ---- From Coordinate System ----
> #Lat/long (Geodetic)
> # +proj=latlong +datum=WGS84 +ellps=WGS84 +towgs84=0,0,0
> # ---- To Coordinate System ----
> #Universal Transverse Mercator (UTM)
> # Cyl, Sph
> # zone= south
> # +proj=utm +datum=WGS84 +zone=47 +units=m +ellps=WGS84 +towgs84=0,0,0
> point 3d30'17.47"N 98d36'27.58"E in WGS84 converted into UTM (zone47)
> (X,Y,Z) = (456423.28,387405.51,0.00)
> Then I want to reverse it back to WGS84.
> I only replace the syntax of cs2cs, before "+to" replace with after
> "+to".
> minnie$ ./cs2cs -v +proj=utm +datum=WGS84 +zone=47 -r +units=m +to
> +proj=latlong +datum=WGS84 << EOF
>> EOF
> # Cyl, Sph
> # zone= south
> minnie:~/Desktop/WGS84/proj-4.4.9/src oon$
> The point UTM (zone 47) (X,Y,Z) = (456423.28,387405.51,0.00) no
> reversible
> into 3d30'17.47"N 98d36'27.58"E in WGS84.
> But the result said "97d59'8.086"E 4d7'43.261"N 0.000"
> What's wrong with my cs2cs syntax?
> btw, why does the Proj library (or cs2cs command) didn't calculate the
> zone automatically for UTM?
> (the manual describe the UTM Zone: every 6 deg, start from 180W to
> 180E)
> thanks.
> regards,
> Oon Arfiandwi
> Software Engineer,
> Bandung, Indonesia.
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
More information about the Proj
