[Proj] proj4-mapserver on windows doesn't work
gegematic gegematic at g-eaux.com
Tue Sep 12 04:44:09 PDT 2006
gegematic wrote:
> Does anyone can confirm me this kind of problem under windows ?
The problem is solved, thanks to a cartoweb user :
It comes from a wrong epsg file, wich is bad for lambert II extended.
the default proj4 epsg file is wrong
i join the fixed epsg file. http://www.nabble.com/user-files/235955/epsg
epsg
View this message in context: http://www.nabble.com/proj4-mapserver-on-windows-doesn%27t-work-tf2215942.html#a6264359
Sent from the PROJ.4 forum at Nabble.com.
