[Proj] Proj4/pj_transform
Hallgren Johan E
jhhal at wmdata.com
Tue Sep 19 07:52:00 PDT 2006
Hello
I have used proj4/pj_transform for a while but I have to ask how you
suggest I should use the library. I want to transform a WGS84 coordinate
from
Easting 16 59 59.97
Northing 62 11 59.96
to RT90 (+proj=tmerc +lat_0=0 +lon_0=15.8062845294444 +k=1.00000561024
+x_0=1500064.274 +y_0=-667.711 +ellps=GRS80 +units=m)
What functions should I use in proj4 to have maximum use of it?
I think pj_transform should be used. But is there functions to convert
lat/long from DMS to decimal degrees?
Regards
Johan
___________________________________
Johan Hallgren
WM-data
Pelle Bergs backe 3
Box 1938, 791 19 Falun
Tel (och mobil): 023-547 46 (int: +46-2354746)
johan.e.hallgren at wmdata.com
<BLOCKED::mailto:johan.e.hallgren at wmdata.com>
http://www.wmdata.se
<BLOCKED::/exchweb/bin/redir.asp?URL=http://www.wmdata.se/>
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20060919/47aaf4bd/attachment.html>
More information about the Proj
