[Proj] WGS84 --> Albers coordinate transformation question
Ed McNierney ed at topozone.com
Tue Apr 10 14:20:13 PDT 2007
Jim -
Thanks; it helps to include all that info in your problem description.  I
assumed you were using the command-line tools and making the common error
confusing the latitude (the Y coordinate) with the X coordinate (input
should be X, Y or longitude, latitude).
I think Eric's suggestion is very likely to be relevant.  Since this is a
problem in some code you've written, could you post the code snippet that's
doing the conversion?
     - Ed
Ed McNierney
President and Chief Mapmaker
Maps a la carte, Inc. / TopoZone.com
73 Princeton Street, Suite 305
North Chelmsford, MA  01863
Phone: (978) 251-4242
Fax: (978) 251-1396
ed at topozone.com
> From: Jim Mace <jmace at benchmarkrs.com>
> Organization: Benchmark Research & Safety Inc.
> Reply-To: <jmace at benchmarkrs.com>, "PROJ.4 and general Projections
> Discussions" <proj at lists.maptools.org>
> Date: Tue, 10 Apr 2007 14:00:32 -0700
> To: "'PROJ.4 and general Projections Discussions'" <proj at lists.maptools.org>
> Subject: RE: [Proj] WGS84 --> Albers coordinate transformation question
> My latitude is 45, longitude -117.
> I am also using a C# wrapper for GDAL/OSR that uses the proj.4 library to
> convert coordinates.  It is only thing I could get to work in an ASP.NET
> application.
> Jim Mace
> Application Programmer
> 201 W. Sprague Ave
> Suite 222
> Spokane, Washington 99201
> -----Original Message-----
> From: proj-bounces at lists.maptools.org
> [mailto:proj-bounces at lists.maptools.org] On Behalf Of Ed McNierney
> Sent: Tuesday, April 10, 2007 12:48 PM
> To: PROJ.4 and general Projections Discussions jmace at benchmarkrs.com,
> Subject: Re: [Proj] WGS84 --> Albers coordinate transformation question
> Jim -
> I get:
> cs2cs +proj=latlong +datum=WGS84 +no_defs +to +proj=aea +lat_1=29.5
> +lat_2=45.5 +lat_0=23 +lon_0=-96 +x_0=0.0 +y_0=0.0 +ellps=GRS80 +units=m
> +datum=NAD83 +no_defs
> -117 45
> -1640181.94     2627681.67 0.00
> Are you entering -117 45 as your input, or 45 -117?
>     - Ed
> Ed McNierney
> Fax: (978) 251-1396
> ed at topozone.com
>> Date: Tue, 10 Apr 2007 12:10:28 -0700
>> To: <proj at lists.maptools.org>
>> Subject: [Proj] WGS84 --> Albers coordinate transformation question
>> I'm trying to convert decimal degrees, in WGS84, to Albers.  My source
> proj
>> string is (+proj=latlong +datum=WGS84 +no_defs), and my destination proj
>> string is (+proj=aea +lat_1=29.5 +lat_2=45.5 +lat_0=23 +lon_0=-96 +x_0=0.0
>> +y_0=0.0 +ellps=GRS80 units=m +datum=NAD83 +no_defs).  When I use the
>> latitude and longitude 45 and-117, respectively, I get the following
>> 0.785398163397449/-2.04203522483337.  Any ideas?
>> Jim Mace
>> 201 W. Sprague Ave
>> Suite 222
>> I am using the free version of SPAMfighter for private users.
>> It has removed 1134 spam emails to date.
>> Paying users do not have this message in their emails.
>> Get the free SPAMfighter here: http://www.spamfighter.com/len
>> Proj mailing list
>> Proj at lists.maptools.org
>> http://lists.maptools.org/mailman/listinfo/proj
> Proj mailing list
> Proj mailing list
