[Proj] invproj call
Seb
spluque at gmail.com
Thu Apr 12 18:38:17 PDT 2007
I've only recently started using proj4 tools directly. I need to do an
inverse projection (back to lat lon geographic coordinates) from an Albers
equal area projection. The projection details for the source are:
projection="Albers Conic"
lat_0=45
lon_0=55
lat_1=40
lat_2=50
No other information is provided, but I assume WGS84 datum. So I wrote
the invproj call like:
invproj +proj=aea +lat_0=45 +lon_0=55 +lat_1=40 +lat_2=50 +datum=WGS84
but I'm getting some strange results, as if the data have been shifted
more than I would expect. Is my call correct based on the given input?
Thanks in advance for any comments.
Cheers,
Seb
More information about the Proj
