[Proj] GK31_Tirol (Austria)
Jens Schwarz jens.schwarz at alpstein.de
Fri Apr 20 00:27:21 PDT 2007
Hello Frank,
thanks for your help!
cs2cs works now. I didn't see that the parameter is called towgs84 for proj and towgs for cs2cs.
I need it in postgis. I don't know if it would be enough to set the cs2cs parameter string as proj4text there.
I'll ask their mailing list.
As we're running web applications, we're also using the javascript port of proj.
The cs2cs port isn't there yet.
Jens
