[Proj] Re: make check fails
Fri Apr 20 22:08:55 PDT 2007
Benoit Myard wrote:
>> The failure always happens on 'testntv2'.
> The 'testvarious' test is failing too.
> Is it a bug and should I report it to the Bugzilla engine or is it
> rather inaccuracies ?
Benoit,
The testntv2 failure is expected because you likely don't have the NTv2
file.  I'm not sure why testvarious is failing though it seems to do so
for me too.  Feel free to file a bug on that.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
