[Proj] Converting NZMG -> Lat Long
Simon O'Malley simonom at gmail.com
Mon Apr 23 19:16:10 PDT 2007
Hi Craig
Of course there is, try the following:
cs2cs +proj=nzmg +datum=nzgd49 +to +proj=latlong +datum=WGS84 -f "%.6f"
This will put you into manual input mode. If you have them all in a
file with coordinate pairs on separate lines then just redirect the
file in like so:
"%.6f"  < nzmgcoords.txt > wgs84coords.txt
The above will give you the lat longs in decimal degrees with 6
decimal places, if you require degrees minutes and seconds just remove
the -f part at the end.
The above command works for me on linux should work on windows
(shudder) but not sure.
Simon
On 4/24/07, Craig Whitmore <lennon at orcon.net.nz> wrote:
> > The link is:
> > http://www.linz.govt.nz/apps/coordinateconversions/index.html?Advanced=0
> > Depends how many you need to do?
> Quite a few more than 5 .. is there a cs2cs command line I can use instead
> or alike?
> Thanks
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
