[Proj] Dutch coordinate system
Paul van der Linden
paul.vanderlinden at falk.nl
Fri Aug 24 06:48:39 PDT 2007
Hi all,
I'm having trouble with coordinate conversion from and to wgs84.
I have tried the various ways which I found here, but none of them seem to work.
The cs2cs example does not work with me (get an projection initialization
failure
cause: unknown projection id
program abnormally terminated
with this parameters:
+proj=sterea +lat_0=52.15616055555555 +lon_0=5.38763888888889 +k=0.9999079
+x_0=155000 +y_0=463000 +ellps=bessel +towgs84=565.040,49.910,465.840,-
0.40939,0.35971,-1.86849,4.0772 +units=m +no_defs)
proj gives similar messages.
I also tried
Projwgs:=TCoordinateTranslator.Create('..\nad');
Projwgs.Open('+proj=latlong +ellps=WGS84');
Projrd:=TCoordinateTranslator.Create('..\nad');
Projrd.Open('+init=epsg:28992');
x := 5.5*DEG_TO_RAD;
y := 51.5*DEG_TO_RAD;
res := _pj_transform(ProjWgs.Pjj,projrd.pjj, 1,0, at x, at y, at z);
but I keep getting
wgs:5.5,51.5 rd:162801,390015
while the correct result should be rd: 162832,390115, according to pctrans,fme,
software based on rdnap.
Can you clarify this for me?
Thanx
More information about the Proj
