[Proj] Dutch coordinate system
Jan Hartmann
j.l.h.hartmann at uva.nl
Sat Aug 25 03:28:11 PDT 2007
Dag Paul,
Please see
http://lists.maptools.org/pipermail/proj/2006-March/002168.html
for a working example of the parameters. Note that proj does not use
datum shifts. you *have* to use cs2cs for that.
Vriendelijke groeten,
Jan Hartmann
Dr. J. Hartmann
Afdeling Geografie
Universiteit van Amsterdam
Paul van der Linden wrote:
> Hi all,
> I'm having trouble with coordinate conversion from and to wgs84.
> I have tried the various ways which I found here, but none of them seem to work.
> The cs2cs example does not work with me (get an projection initialization
> failure
> cause: unknown projection id
> program abnormally terminated
> with this parameters:
> +proj=sterea +lat_0=52.15616055555555 +lon_0=5.38763888888889 +k=0.9999079
> +x_0=155000 +y_0=463000 +ellps=bessel +towgs84=565.040,49.910,465.840,-
> 0.40939,0.35971,-1.86849,4.0772 +units=m +no_defs)
> proj gives similar messages.
> I also tried
> Projwgs:=TCoordinateTranslator.Create('..\nad');
> Projwgs.Open('+proj=latlong +ellps=WGS84');
> Projrd:=TCoordinateTranslator.Create('..\nad');
> Projrd.Open('+init=epsg:28992');
> x := 5.5*DEG_TO_RAD;
> y := 51.5*DEG_TO_RAD;
> res := _pj_transform(ProjWgs.Pjj,projrd.pjj, 1,0, at x, at y, at z);
> but I keep getting
> wgs:5.5,51.5 rd:162801,390015
> while the correct result should be rd: 162832,390115, according to pctrans,fme,
> software based on rdnap.
> Can you clarify this for me?
> Thanx
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
More information about the Proj
